I think i didn't find any discussion about that, my logo placement is very bad,
I don't think i want to use the shield, my logo is horizontal.. but it looks like it appears exaactly where i want my menu items...
i want it to be bigger and at the left part of the menu,
any hint?
thx in advance
http://www.tolede-evenements.fr/
One is a shield, a background for logo image - this image width is used to separate navigation menu items.
Second is logo image.
You don't have this first one.
don't forget to remove logo image from where it's now (Layout>>Logo image)
also can we enlarge height of header, so logo can be bigger?
maybe with something like this:
#main-menu {
height: 120px !important; }
I'd like my logo not to move, by any means. If possible at the left of the menu but if it's center then ok.
what is the step by step
and set 'Hide logo when header is stuck' with the same value as 'Logo image top margin'
so i guess this last tip you gave me does'nt work because of that?
