Hello there,
I have a couple of contact forms on my site: one on a contact page and one on the footer.
The one on the contact page is ok, but I would like the one on the footer to have a smaller textarea (so you don't have to scroll).
I have seen here
http://contactform7.com/text-fields/ that you can set the number of cols and rows of the textarea but it does not work. It looks that it is fixed on some CSS, so my question is:
How can I reduce the size of rows on my footer form without changing the one on contact page?
Thank you very much.
You will need custom CSS for that. Try this With kind regards.
Thanks.
