header logo
I think i didn't find any discussion about that, my logo placement is very bad,
I don't think i want to use the shield, my logo is horizontal.. but it looks like it appears exaactly where i want my menu items...
i want it to be bigger and at the left part of the menu,
any hint?
thx in advance
http://www.tolede-evenements.fr/
    This page element is build with two images.
    One is a shield, a background for logo image - this image width is used to separate navigation menu items.
    Second is logo image.
    You don't have this first one.
    the shield was black and couldnt see the logo with the black background, also, I don't have access to this black shield anymore
    ok, so upload logo image as a shield image (to 'Logo shield image' in 'Layout >> Header'), that will do.
    don't forget to remove logo image from where it's now (Layout>>Logo image)
    ok better, but when scrolling the logo shield goes away.
    also can we enlarge height of header, so logo can be bigger?
    maybe with something like this:
    #main-menu {
    height: 120px !important; }
    Vlad said: also can we enlarge height of header, so logo can be bigger?
    You can use 'Logo image top margin' parameter to set this up.
    ok I'll refrase:
    I'd like my logo not to move, by any means. If possible at the left of the menu but if it's center then ok.
    what is the step by step
    Go to Chillout Options >> Layout >> Logo
    and set 'Hide logo when header is stuck' with the same value as 'Logo image top margin'
    you said "don't forget to remove logo image from where it's now (Layout>>Logo image)"
    so i guess this last tip you gave me does'nt work because of that?
    Well, then use a transparent image for a shield and move logo image to logo section, or make the current logo image (used as a shield) with some space in the top.
