Woocommerce Title Problems
in FatMoon Posts: 293
Hello
Slowly but surely everything comes to life.. but for an odd reason woo commerce titles stick to my header logo and don't seem to react to the general settings? (see screenshot). All I need is to have all titles (like portfolio) at the same position.. any help on this?
Also the "Shop" page doesn't display the title (while cart and checkout stick to the logo)
Thanks Pascal
    Go to Customizing ▸ Shop(woocommerce) settings ▸ Products list ▸ Hide content under header and set it to "Turn it off"
    Check what it will fix, and send me link to thing that is not fixed.
    Hello
    Unfortunately this setting doesn't change anything at all
    Link is flyart.com (order something in the shop to access "cart" and "checkout"). As the website is in maintenance mode please use login provided to you through private message
    Thanks, Pascal
    1765 x 1169 - 182K
    1207 x 1025 - 96K
    Hello
    I found a workaround that is OK for me. Thanks
    Great :-)
    Thanks for info.
