I noticed another problem.. when having a narrow window on destop or using a mobile device the header doesn't stick to the top but has a gab were it show content when scrolling (see screenshot) Thanks for your help! Pascal
It is admin bar- don't worry about it, user wont see it, and this issue with admin bar is only in mobile view. I can give you CSS that will position header at top with admin bar in this narrow view, but only you will see difference.
I can't check cause you have maintenance mode on, but isn't it gap caused by admin bar? Check without admin bar.
I just tried without admin bar and as you said it's all good now. I don't need css to "fix" that
Pascal
