Visual Composer broken
in Blame Posts: 1
It seems that visual composer is not working in the current version of the theme, this looks to be because it needs to be updated. Is there going to be an updated release to fix this?
Thanks,
Joe
    Hi there:-)
    When did you bought Blame theme ? In latest theme version there is VC in version 4.12 so it should work fine.
    However 4 days ago there was release VC 5.0, so soon I will checkout how it works with theme and then update if everything is good.
