Hello! Which plugin exactly is crucial for you to update? Do you encounter any kind of problems or lack of functionality related to plugins bundled with theme?
Hi, There are two plugins asking to be updated. 1. Visual Composer extend by Apollo13 2. WPBakery Visual Composer
I am currently on ChilloutVersion: 1.2.8
I am not sure what the current version is but I have not received any updates for a while and not sure if I am supposed to... I understand my support has expired however does that also mean updates have stopped?
You can set it in your ThemeForest account settings - to get notifications about new versions of item you purchased.
So that is the latest version, great.
My question is I was not notified via email that an update had been released like I used to.
Is there any reason why I may not have been notified?
We are not sending notifications about new releases.
Go to your Envato account >> downloads and check 'Get notified by email if this item is updated' checkbox.
Thanks for getting back to me.
