Plugins installation errors
I need help for this plugin installation errors:
Install Required Plugins
The installation and activation process is starting. This process may take a while on some hosts, so please be patient.
Installing and Activating Plugin Apollo13 Thirteen Post Types (1/3)
Downloading install package from https://x.x.x.x/wp-content/themes/thirteen/advance/plugins/a13_thirteen_cpt.zip
An error occurred while installing Apollo13 Thirteen Post Types: Download failed. cURL error 60: Peer certificate cannot be authenticated with known CA certificates.
Installing and Activating Plugin Envato WordPress Toolkit (2/3)
Downloading install package from https://x.x.x.x/wp-content/themes/thirteen/advance/plugins/envato-wordpress-toolkit.zip
An error occurred while installing Envato WordPress Toolkit: Download failed. cURL error 60: Peer certificate cannot be authenticated with known CA certificates.
Installing and Activating Plugin WPBakery Visual Composer (3/3)
Downloading install package from https://x.x.x.x/wp-content/themes/thirteen/advance/plugins/js_composer.zip
An error occurred while installing WPBakery Visual Composer: Download failed. cURL error 60: Peer certificate cannot be authenticated with known CA certificates.
All installations and activations have been completed.
TGMPA v2.6.1
Return to Required Plugins Installer
I am using Vultr VPS (4.6.1 wordpress pre-build),
Many thanks!
