If I upload an image that's too small for a blog post, the image tiles (lots of the same image side by side in header). Is there any way to stop this and just have the single image? We can't always upload big images/the correct resolution for blog posts. Screen shot attached.
In options for title bar for blog, in option "How to fit background image" set "just center". It should do the trick.
Thanks guys
