Feature image - opening as black lightbox - would prefer to link to page
in Chillout Posts: 54
Hi Apollo,
We have an Events calender installed on our website, which uses a "Feature Image". When this image is clicked it opens the lightbox feature of the theme (Displays as black box). I would prefer that the image links to a page instead?
Is there a setting I can change to ensure that the image does not open in the lightbox, but instead links to the page instead.
http://tinyurl.com/j3rnu7a
Thanks,
Mandy
    Hello Mandy,
    if you add 'block_cb' class to image or anchor - it will prevent opening lightbox.
    Thanks Apollo, will give that a try. Will let you know how it goes.
    Hi Apollo,
    Thanks for your suggestion. I've tried a few things, but I am struggling to see where I can apply the 'block_cb' class to image or anchor.
    Please are you able to advise where I might find the code for this?
    Thanks,
    Mandy
    Please send me login credentials, point the page/post you want to modify and the image which you want to address.
    Credentials send via private message, please.
