Discussions
Categories
Home
Thirteen
Adding a footer
flecoq
February 2017
in
Thirteen
Hello, Do you think it's possible to ad a footer on the template ?
Air
February 2017
Could you explain your question further?
flecoq
February 2017
Sure, I'd like to have a footer container to put plugin in it. if it's possible for sure
Air
February 2017
Still I am not sure what you mean. Plugin in footer? Maybe you mean widget?
flecoq
February 2017
on basic templates for wordpress you always have a footer area for widget. that's what i like to get on my website
Air
February 2017
Oo so widget in the end, not plugin :-)
However thirteen theme has so small footer, like it almost doesn't have any :-)
There is only place for some text
http://apollo13.eu/docs/thirteen/#!/footer_content
However you can use
Header default widget area
http://apollo13.eu/docs/thirteen/#!/widgets
to put some widgets just above footer.
UNLESS you mean as footer some different place then we defined in our theme, that is bottom of "header" part.
I am off for tonight.
flecoq
February 2017
"UNLESS you mean as footer some different place then we defined in our theme, that is bottom of "header" part."
That's what I mean...
Air
February 2017
So use
By the way - what you are planing to add there?
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
114
OneLander
324
PhotoProof
590
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
February 2017
flecoq
February 2017
Air
Discussions
Categories
Sign In
There is only place for some text http://apollo13.eu/docs/thirteen/#!/footer_content
However you can use Header default widget area http://apollo13.eu/docs/thirteen/#!/widgets to put some widgets just above footer.
