Adding a footer
Hello, Do you think it's possible to ad a footer on the template ?
    Could you explain your question further?
  • Sure, I'd like to have a footer container to put plugin in it. if it's possible for sure
    Still I am not sure what you mean. Plugin in footer? Maybe you mean widget?
  • on basic templates for wordpress you always have a footer area for widget. that's what i like to get on my website
    Oo so widget in the end, not plugin :-)
    However thirteen theme has so small footer, like it almost doesn't have any :-)
    There is only place for some text http://apollo13.eu/docs/thirteen/#!/footer_content
    However you can use Header default widget area http://apollo13.eu/docs/thirteen/#!/widgets to put some widgets just above footer.
    UNLESS you mean as footer some different place then we defined in our theme, that is bottom of "header" part.
    I am off for tonight.
  • "UNLESS you mean as footer some different place then we defined in our theme, that is bottom of "header" part."
    That's what I mean...
    So use Header default widget area.
    By the way - what you are planing to add there?
