Hello, I want to change the permalink from "www.mysite.com/works/lorem-ipsum/" to "www.mysite.com/expeditions/lorem-ipsum/" for all Work Items generally.
borzo83 said: How can I do that? Do I have to edit an php file?
Yes, basicly one line in ..\wp-content\plugins\chillout-plugin\chillout-plugin.php line 25. change: define('A13_CUSTOM_POST_TYPE_WORK_SLUG', 'work'); to whatever you want
Is it possible to make the slug name the same as the name of the genre.
Let's say I have 2 'Works', the first one (mywork-1) is assigned to the genre "Apple" and the second one (mywork-2) to "Pear". What I want is that the URL looks like this:
Work 1 assigned to genre "Apple": www.mysite.com/apple/mywork-1/
Work 2 assigend to genre "Pear": www.mysite.com/pear/mywork-1/
I assume I have to manipulate again this line: define('A13_CUSTOM_POST_TYPE_WORK_SLUG', 'work');
line 25.change:
But how?
Thanks in advance!
To rewrite slug dynamically better look for something like
https://pl.wordpress.org/plugins/custom-post-type-permalinks/
manipulate with permalink structure that will take taxonomy ('genre') in count
