So antoher problem appeared, i just see on my iPhone 6 the "Photon Logo" not my own one. In addition to that is the dropdown menu covering the Logo itself, it just does not look well and is harder to read.
Hey Air, thank you for your help but my logo-problem is not 100% solved. The solution with the Top Space Value did not worked out on the mobile version. The Logo is still hiding the titel. I even tried bigger values up to 600px...
Any sollutions?
Change HIGH dpi logo: http://apollo13.eu/docs/photon/#!/customize_logo
With kind rreagrds.
Try this custom CSS: With kind regards.
