If you have version 1.1.9.1(you can get it here https://apollo13themes.com/rife/#downloads ) of Rife theme then just add code in Appearance -> Rife License Code See this
Don't worry about all the confusion - we just updated our plans yesterday, when we finally released auto-updates, and you were still on older version of theme that didn't had auto-updates yet. Anyway from now on, it should go smooth ;-) If not we are here for you!
contentologue said: So, it means that we won't know from the admin when we have to update it, and we can't update it from the admin neither, right ?
In older version - yes, you won't know.
In this new one(1.1.9.1), update will be available as other updates in WordPress for plugins or themes, so you will get info about it in your admin panel :-)
See this
https://apollo13themes.com/rife/license-code/
It will remove banner :-)
Remember that we have added the auto-updates so when you add the code you no longer have to worry about updating the theme
With Regards
I checked 3 times if I copied the right code.
You can get this better version from https://apollo13themes.com/rife/#downloads
Anyway if you need anything we are here( when in office of course ;-) )
