Help....I have disactivated Visual Composer, cause your last change logs were saying it has been updated to 5.1.1, and it was not updated...
I was thinking that by disactivating it and reactivating it, it would be ok, and now, I can't activate it at all.
Also, you told me to disactivate Revo in order to use Visual on front end properly, and now I am scared to disactivate it and that I can't reactivate it like it does now for visual.
Thank you,
Sophie
EDIT : I clicked on update (thought it was a paying upgrade button).
contentologue said: I was thinking that by disactivating it and reactivating it, it would be ok, and now, I can't activate it at all.
If with update of plugin it will not activate, try removing it completely and then install it again from theme.
contentologue said: Also, you told me to disactivate Revo in order to use Visual on front end properly, and now I am scared to disactivate it and that I can't reactivate it like it does now for visual.
Don't worry. As I remember you have lot of plugins there, so maybe there is some conflict/blocking between them. If you will not find a way to solve it(Disable all Plugins, and then try to enable only VC and/or Revo) then I will try to do it for you on Monday.
contentologue said: I clicked on update (thought it was a paying upgrade button).
Oh sorry, I mean, I've solved the problem by clicking on "update" on Visual Composer. It didn't have any "activate" button so I freaked out. No problem anymore.
http://apollo13.eu/docs/rife/#!/installation_update_bundled_plugins If with update of plugin it will not activate, try removing it completely and then install it again from theme.
What do you mean exactly?
