Customizer does not work - Redux issue
in Rife Posts: 2
Hi there, I'm using the RIFE theme and I saw your announcement about theme customize not working with new Redux installation. I'm getting that problem, and the workaround to install version 3.6.4.1 does nothing.. when i hit customize it takes me to my homepage.. weird. I would be most grateful for some help. Thanks in advance
    rubior said: when i hit customize it takes me to my homepage
    Yes, that is different issue. I am not sure what can it be, maybe other plugin, or some server protection.
    I you don't mind I would like to take a look.
    Details sent. Thank you
    Thanks for data.
    I am not sure about it, but I suspect that problem is in server settings. As you can see in this screen shot:image
    There are two problems. I mostly suspect "PHP Post Max Size", because Rife theme has so many settings, that there is a chance that they don't fit in just 8MB.
    However this is pure guess. I didn't face such issue yet.
    1022 x 447 - 17K
