Hi! I am trying to customize the theme and change logo. Uploaded image doesn't show up. In fact, I had upload it and after saving and refreshing the page, the settings changed from Image to text... it doesn't let me use image as logo. Why ? Please see the image attached.
Ok, I don't know what was that but it works now. Logo disappears on other pages (there is a link to home page but no logo shown). How can I make it be fixed on all pages (not only the home page ) ?
Hi! I cannot do it because the website has not been launched yet. Meanwhile, could you please tell me where I can replace background photos of the home page ?
You won't see it if I give you the link. I have a coming soon mode. And I can't give you access to the server now. Any ideas what can I do with logo ? I have cleared cache data.
1. You have set logo in Appearance->Customize->Header settings-> Logo ? 2. You have removed any logos set in: a) Appearance->Customize->Header settings-> Variant light - overwrites b) Appearance->Customize->Header settings-> Variant dark - overwrites c) Appearance->Customize->Header settings-> Sticky header - overwrites ? 3. You have also marked Customizing ▸ Header settings▸ Logo▸Use logos from header variants ▸ Disable ?
If every question have answer "yes", then there is some other issue.
On page where logo doesn't appear check with firebug( or similar tool) what is path to file for logo, and does it exist and is reachable for server.
Have you cleared cache in your browser?
I asked for link to your page, so I could investigate what can be the reason. I can not check anything with screen shot :-)
Please start new topic, and mark on screen shot which images you like to change exactly. Thank you:-)
You can try to switch off changing off logo in Customizing ▸ Header settings▸ Logo▸Use logos from header variants ▸ Disable
What was the problem in the end?
