Image Logo
edited May 2017 in Agency Posts: 39
Hi! I am trying to customize the theme and change logo. Uploaded image doesn't show up. In fact, I had upload it and after saving and refreshing the page, the settings changed from Image to text... it doesn't let me use image as logo. Why ? Please see the image attached.
Post edited by Eleira on
  • edited May 2017 Posts: 39
    Ok, I don't know what was that but it works now. Logo disappears on other pages (there is a link to home page but no logo shown). How can I make it be fixed on all pages (not only the home page ) ?
    Eleira said: I don't know what was that but it works now
    It had to be "stucked setting" - good you managed to do it.
    Eleira said: Logo disappears on other pages
    Could you post link to example page, so I could see what is going on?
    Have you cleared cache in your browser?
    Sorry, I took a while to come back to you. Yes, please see the screenshots attached.
    1343 x 403 - 115K
    1296 x 489 - 21K
    Hello again:-)
    I asked for link to your page, so I could investigate what can be the reason. I can not check anything with screen shot :-)
    Hi! I cannot do it because the website has not been launched yet. Meanwhile, could you please tell me where I can replace background photos of the home page ?
    Eleira said: I cannot do it because the website has not been launched yet.
    Then send link with private message please(click on my nick, in top-right corner you will find option "Message")
    Eleira said: please tell me where I can replace background photos of the home page
    Please start new topic, and mark on screen shot which images you like to change exactly. Thank you:-)
    You won't see it if I give you the link. I have a coming soon mode. And I can't give you access to the server now. Any ideas what can I do with logo ? I have cleared cache data.
    edited May 2017 Posts: 10,970
    Only thing I can think of is header color variants http://apollo13.eu/docs/apollo13_framework_theme/#!/header_variant_light_dark
    You can try to switch off changing off logo in Customizing ▸ Header settings▸ Logo▸Use logos from header variants ▸ Disable
    Ok, it didn't help...I will send you the access details. Hope you will help me..
    OK.
    1. You have set logo in Appearance->Customize->Header settings-> Logo ?
    2. You have removed any logos set in:
    a) Appearance->Customize->Header settings-> Variant light - overwrites
    b) Appearance->Customize->Header settings-> Variant dark - overwrites
    c) Appearance->Customize->Header settings-> Sticky header - overwrites
    3. You have also marked Customizing ▸ Header settings▸ Logo▸Use logos from header variants ▸ Disable ?
    If every question have answer "yes", then there is some other issue.
    On page where logo doesn't appear check with firebug( or similar tool) what is path to file for logo, and does it exist and is reachable for server.
    said: Customizing ▸ Header settings▸ Logo▸Use logos from header variants ▸ Disable
    1257 x 555 - 35K
    Hi. I have just removed all variants
    Ok..it's working now....
    That is great!
    What was the problem in the end?
    There were images under the header variants. I think that was the problem. Thank you for all of your help and fast responses!
