hey! Is there a way I can replace the background images on the home page (I uploaded demo files) ? For instance, where can I change the background image of the slider ? In the slider settings, the background is transparent. Thank you!
Ok, it's smth weird. The image showed up finally. But I have two more issues: 1) The logo doesn't show up; 2) I changed the image of "Circles" in Works, but it is not shown on the page.
Lets continue in your original topic about logo - I told you there how to help me debug it;-)
Eleira said: 2) I changed the image of "Circles" in Works, but it is not shown on the page.
Possible that you have caching plugin that prevents changes from appearing for some time. However I can tell when I will get link to your site finally:-)
Ok, the same happens with other works..I replace the featured image and it is displayed like a tiny square on the top of the page...that i cannot even see if I don't hover over. What's going on ?
I need link to see what happens, I can't guess what is going wrong in your installation.
I know you limitations about giving me access, but you could create temporary access for me, that you will delete after I am done inspecting.
Please send me temporary access to your WordPress so I could check there what is going on. Send it here on forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
By sending access to WordPress I mean: -create new ADMIN account with fake e-mail -set some password to this account -send me created login and password
Hi there. The images finally showed up after I had duplicated the pages and uploaded them to the duplicated pages. But I have other issues (I will open a new thread). I will send you the message with the passwords, as well as instructions how to connect to the server (it will be through putty).
What you have marked on your screen shot it exactly background image used under revo slider. So just swap it :-)
I found the image....what's wrong with it ?
Thank you for your help.
