Updating to version 1.3.0 FAIL
edited June 2017 in Rife Posts: 6
Hello Apollo13Team, I´m updating the theme to the last version but it seems to be a problem and It can´t allow me to update. I´ve just paid the 50 plan. I send you a screenshot (error while updating. Download failed). Could you help me?
I have 4.7 version of WP and 1.2.0 of RIFE
Post edited by GianDeveloper on
    edited June 2017 Posts: 10,970
    Hello there :-)
    This is sometimes happen on some servers. Probably your server admin have to update some library on server as described here https://unix.stackexchange.com/a/192953
    Edit:
    it can be fixed by editing theme files, so you need to ask admin to update server.
    If you need update quicker we can send you it by e-mail.
    I have edited my answer as I realized, that it can't be fixed by editing theme files, as this change have to be done in server configuration.
  • Hey Air! Thanks you, but it seems that I can´t update the server. Is there any way to have the last version zip or update rife theme via FTP?
    Hey Gian.
    Please try again with auto update as I moved updated file to other server so now SSL (https) shouldn't be problem. I did it 24 hours ago.
  • Oh, yes!! Now it´s perfect, so much thanks Air!
