Problem with Slider on Albums
Helo Apollo13 team. I have a problem with sliders in albums that I couldn´t solve. I don´t have any problems with brick albums, but, when I change to slider option, the page is all in blank space. I don´t see anything, neither images or the header. I don´t know why and I've checked all the slugs. How can I solve this?
Thanks you for the support! :)
    Hello there:-)
    If you could, please switch one example album to slider and send me link to it so I could see is there any JavaScript error.
  • Hello Air. I export all the Rife theme from Apollo13import on mi wordpress and I´m working with that template. But I can´t work with album sliders neither work sliders.
    I didn´t change the template I exported, here you have the pages examples of my web:
    Album Example: http://www.gianfrancovisuals.com/album/fullscreen/
    Work Example: http://www.gianfrancovisuals.com/work/elegance-ios-ui-kit/
    As you see, all is in blank space.
    Hello again:-)
    Try disabling Layer Slider plugin. I suppose it "steals" our library. I will check is there any conflict with that plugin.
  • Problem solved! <3
    That is great, I will check on later, is there anything I could do better to avoid conflict.
    Thanks for help!
