If you mark text, you will see you get 404 error page. By the way you should customize this page to make text visible ;-)
You get 404 probably cause of permalinks issue, and you have to refresh them.
Go to Settings->Permalinks and change to default one first. Save and check if your site is working any better. If yes, then go and change permalinks again and check how is your site now.
Hope everything is fine with you. I just wanted to ask if I need to refresh permalinks on a constant basis? I have noticed that it happened again today..And was a bit frustrated :-/
Thanks, I am fine now. My hand will be in one piece again after 5 weeks ;-)
Eleira said: I just wanted to ask if I need to refresh permalinks on a constant basis?
You only refresh permalinks when you mess with way how URLs are created, like when editing slug of works.
If you didn't made same change again, then maybe you have installed some plugin that did fancy things, or different plugin is changing something regularly?
I have done it, so please check is it all.
Thanks, I am fine now. My hand will be in one piece again after 5 weeks ;-) You only refresh permalinks when you mess with way how URLs are created, like when editing slug of works.
