Visual Composer Install fails
in Thirteen Posts: 4
Dear Sir,
i now installed your beautiful Template. After installing plugin, it show me that the plugin installation of js_composer.zip goes wrong.
Before that is not installed, i cant install the demo data.
Pls help..
    By installing plugin will shown:
    Request failed: Parseerror
    Hello there:-)
    Please try installing Visual composer manually then. You can find it in wp-content/themes/thirteen/advance/plugins/js_composer.zip
    Please tell if helps.
    Hey there,
    i tried already. It doesn't works.
    That is strange.
    You had some older, or not fully installed VC on your server, and it blocked manual install. Now it works :-)
    THX :D
