On single work page, the content is being displayed in a very small size. Utilizing 30% of the page. Instead BIG title text is using a great portion of the screen.
Site:www.artisticeyephotographers.com
Enclosing the actual and desired images named respectively.
Opening single work to lightbox was desired for scenario when you actually have some text in you single work.
If you plan on opening each "work" just to lightbox as single photography, then I advice using rather single work, or singe album as it also have option for filters(categories).
Example : http://rifetheme.com/fatmoon-brooklyn/album/uncover/
You can link such single album/work as your front page with any problem http://apollo13.eu/docs/apollo13_framework_theme/#adding_frontpage
But, I just checked the link above, if i can do like with filters on the top for albums or work list page as well. It would work as a charm.
Thanks.
By the way, any chance i could remove that download button from the top bar in light box ?
Customizing ▸ General settings▸ Lightbox settings ▸ lightGallery download control
