Issue bottom of front page
Please take a look at the image below:
http://prntscr.com/gzn8k0
How can i fix this ????
    Hello
    I'm not sure what will help you because I don't see your page from backend so try one of these possibilities:
    1) If you use the text block to display Slider Revolution use the standard shortcodes for sliders: http://nimb.ws/3XP6K8
    2) If you still want to use the text block you must change the margin-bottom to 0px: http://nimb.ws/gdNE6l
    P.S If it won't help, send me the screenshot from your backend. It will help me a lot :)
    With Regards
    Lead Graphic Designer
    Just tried each step none work, I have not modified anything previously either this just occurred out of no where. Can you please help ? Below is the backend.
    https://i.imgur.com/NRcSYE8.png
    Can someone please assist me ?
    In these two places: http://nimb.ws/t1Y8Np go to the design options tab and add 0px to margin-bottom.
    If it won't help send me temporary access to your WordPress so I could check there what is going on? Send it here on forum via private message (click on my nick, in top-right corner you will find option "Message"). In message please attach LINK to topic it applies to.
    Send you a message now, I tried that still don't work
    Hello again
    Now it looks as it should.
    I'm not sure why but the shortcode "Revolution Slider" had the bottom margin so I changed it to another shortcode "Revolution Slider 5". ( http://nimb.ws/KDeJnq )
    With regards
    Thank you very much Daniel!
