Unable to go to the article section (only html code)
Dear support team,
I go the following problem:
After playing around with WP Composer, I wasn't able to see the list of all my articles anymore. The list line of the html code was:
{"success":false,"data":{"code":"Wrong ID or no Template found"}}
I think the reason is, that one of my articles has an assigned template which I deleted somewhere in the past?!
It would be really great, if you could verify this.
Thanks and kind regards, harald
    Yes, this was the case: Never ever remove a WP Composer template which was assigned to an article. Wouldn't be a great idea to have something like a safe guard to void such situations?
    Kind regards, harald
    I see you have found solution quickly, that is great!
    tensor said: Wouldn't be a great idea to have something like a safe guard to void such situations?
    I think it would! However this is not our plugin, so we don't have much power about its safety design, but you got point there!
