I just installed the photoproof theme and imported theme demo II. The slider revolution doesn't seem to be working. It says its not activated, can you please check and let me know. Attached are screenshots for your reference.
No revolution slider is not needed in demo II. Cause you didn't import demo with option Remove current content now you have to setup Album as homepage manually.
However change from my previous answer should give you results.
Thanks, I did import the demo with remove current content option but still not working. But in any case for now i want to use demo II, so wont need revolution slider. Just a quick question though, on home page I am showing one of the album, but when i click on home in the menu it doesn't highlight or mark it in active state. How can i do that?
Just a quick help again, the domain that i shared with you was a development domain and now i want to move the site to the production url and changing the hosting as well. Will i have to make any changes to get the theme and all my settings working or normal wp-config change should work?
When i moved the server, its just showing white screen and doesn't run the frontend. Backend is working fine. So what can be the issue. Please help me out asap, need the site live tomorrow morning, Have a really big show.
Ok, so its working the frontend now, but all my settings are gone. Whatever changed had made from customize tab. Will i have to make all the changes again? This is what it should have looked http://jimozproduction.in/mpsg/
Thanks for contacting us!
I think you face same issue as other user here: https://support.apollo13.eu/discussion/5143/rev-slider-not-importing#latest
You probably didn't mark option Remove current content while importing demo data.
You can fix it by going to Settings -> Reading, and setting your Homepage as Home.
Did this, but still doesn't work. For demo II of the theme is revolution slider needed?
Try setting album as front page - maybe settings need refreshment. It is explained here http://apollo13.eu/docs/apollo13_framework_theme/#adding_frontpage
Could you send link to your site so I could see it live?
Link to site: http://jimozproduction.in/mpsg/
I think best way to make it highlight would be to add custom link to your menu, that is just address of your site, like this:
Now it should be good.
Link: http://www.mpsgweddings.com/
I can not assist you like in normal workday, however have you moved your website like explained here https://codex.wordpress.org/Moving_WordPress ?
In any case you try to move settings from 1st page to 2nd using this solution https://support.apollo13.eu/discussion/comment/20824/#Comment_20824
