Top Bar
Trying to figure out what the Top bar options do.
I am using the default demo with header, then turned on the top bar. Tried changing text/link/hover color, but they don't do anything.
Tried to change "Social icons" color to white or black or semi-transparent, but they stay in color.
"Message part" and "Message text" don't appear to show up or change, I can't see them having an effect on the top bar.
Image: https://imgur.com/a/DNudY
Tried on: Windows/Chrome, iPhone/Safari
Documentation:
"Header - Top Bar
It is for horizontal header only!
Here you can set upper part of header. You can set almost every color of it here. Also you can choose to use Message or Use menu from Alternative short top bar menu position.
This is also part that we choose for Language switcher if you use WPML plugin."
