Hi!
I need a menu link to open on a new tab, but I wasn't able to do so using html since (apparently) there is no direct way to input any html code on menu itens.
The website I'm working on is
http://grupofluxe.com.br/siteThe link that I need to open on a new tab is the "escola" item.
Could you please help?
Thank you guys!
Sure, please see this explanation https://www.megamenu.com/documentation/how-to-open-menu-links-in-a-new-tab-or-window/
This is standard WordPress feature.
It solved my problem!
I'm a little disappointed with my google skills, though. hahahahaha
Best regards!
