Editting the people lay-out
edited February 2018 in OneLander Posts: 6
I'm trying to find a way to edit the people's layout. I want to remove the social media icons. Would be great if someone could advise. Thanks! :)
Edit: I also like to increase the font size of the text
Post edited by DePlatenbaas on
    edited February 2018 Posts: 10,970
    Hello there:-)
    As for removing socials then just go edit people(Admin area-> People) http://rifetheme.com/apollo13-framework/docs/content-management/people-post-type/ and remove links in social profiles options.
    As for font size try this custom CSS:
    .object-item .people-desc {
        font-size: 14px;
        max-height: none;
  • Thanks. Where do I add the custom CSS? Tried it in both these places, but didn't change anything.
    439 x 74 - 13K
    436 x 78 - 18K
    Custom CSS field should be alright, however I have made error in my code. I have updated my previous answer, so please copy this custom CSS again.
  • Thanks. It works now. However the text is cut off on the bottom. Is there a way to extend the text field?
    605 x 529 - 444K
    Sure:-) I have update CSS from first post once again, please use it.
  • Thanks a lot! Also for your quick reply! :smile:
