What do you find problematic? If you look for managing content in Elementor then this is not covered in theme documentation, as this is explained in Elementor plugin documentation.
My Apologies, the documentation that comes packed with the theme is not for this particular theme, however, I see that there is the correct documentation through a link located on the Wordpress homepage. Thank You for you help. Cheers!
Is there a way to make the showcase "work" responsive on mobile device so that it doesn't get cropped out on the left and right sides? It actually does this on the demo as well. Example attached. Thanks!
You can do such trick, however it will affect all resolutions: 1. Go edit work this images belongs to. 2. Work details -> Works Media -> Present media in: -> Slider 3. Work details -> Works Media -> Fit images -> Fit when needed
You can also experiment with other variants. It all depends how you expect your images to behave :-) One will like to cover white space, while other want all image to be visible :-)
I believe it is
alt
text from missing images. So just remove those images that are missing.I didn't see it previously cause FireFox don't display
alt
s.With kind regards.
This is documentation for this theme http://rifetheme.com/apollo13-framework/ .
You will find there all topic related to theme things.
However If you look for info about theme shortcodes then it can be found here http://rifetheme.com/apollo13-framework/docs/content-management/shortcodes/
