How can I remove this vertical bar from menu header?
I finally have an Awesome RIFE client site UP!! This is the only thing I can't figure out in header options, the vertical bar to the far right of menu header
http://thomaseditions.com/
BIG UPS RIFE Fam!!
    Hey there!
    Go and find option Header separator and lines color and set its color to 0 in opacity - this will make it disappear.
    In your case you will have to do it in:
    Appearance → Customize → Header Settings → Sticky header – overwrites
    Appearance → Customize → Header Settings → Variant light – overwrites
  • Ahhhh GRT! now I know, worked like a charm thnks for getting back to me w a fix so quick
    and LUV Elementor AND Rife!!
