I finally have an Awesome RIFE client site UP!! This is the only thing I can't figure out in header options, the vertical bar to the far right of menu header http://thomaseditions.com/
Go and find option Header separator and lines color and set its color to 0 in opacity - this will make it disappear.
In your case you will have to do it in: Appearance → Customize → Header Settings → Sticky header – overwrites Appearance → Customize → Header Settings → Variant light – overwrites
and LUV Elementor AND Rife!!
