I recently realized that I’m latterly getting this error on many of my sites:
GET
https://fonts.googleapis.com/css 400 ()
I use the Google font "Montserrat" (activated through the "Fonts" menu in the theme’s backend). Do I have to update anything manually? Adding CSS code to style.css or in the custom CSS field in the theme’s backend ("Appearance")?
I just don’t get rid of this error…
Thanks.
Failed to decode downloaded font:
(index):1 Failed to decode downloaded font: https://fonts.gstatic.com/stats/Montserrat/normal/400
df983.js:1 Failed to decode downloaded font: https://fonts.gstatic.com/stats/Montserrat/normal/400
(anonymous) @ df983.js:1
Sa @ df983.js:1
I have never seen such error, but I have found such info about it https://stackoverflow.com/questions/30442319/failed-to-decode-downloaded-font
Maybe it will help.
<link rel='stylesheet' id='evcal_google_fonts-css' href='//fonts.googleapis.com/css' type='text/css' media='screen' />
Seems like plugin for me.
Font "Montserrat" works fine in your menu, as it is selected from theme options. So you don't need to do anything else.
