LivIcons Update
in Starter Posts: 3
LivIcons is asking for a purchase code in order to be update, how can I get it?
    Hey there:-)
    Do you really need to update it for something? We will add update for it in next Starter Theme update, as they released their update after we released ours.
    Read more about bundled plugins https://rifetheme.com/apollo13-framework/docs/installation-updating/installing-the-plugins/
    Thanks for your feedback, definitely bad timing. When do you think next theme update will be available?
    When there will be anything to update ;-) I didn't even start changes for next version, as we released update yestreday:-)
    Do you need update of LivIcons for something special? Do you anticipate anything in that update?
    Just for security reasons, I'll be waiting for the next update then.
    Thank you!
    Change log of new version:
    -- Updated GreenSock Animation Platform files with the latest versions
    -- Updated Verge script with the latest version
    -- Added 4 new icons: cpu.svg, headphones.svg, radiation.svg, scales.svg
    So no security updates. So don't worry that you missing anything special ;-)
    In my opinion author gave up on this plugin long ago, after all, it is first update after 14 months.
