Hello!
I have a problem.
The uploaded images, in small size on the screen, are pale, unobtrusive. Images in the apollo_images directory are bad. What can I do?
I paid the most recent version in the days.
I have used this to date. I was hoping the update would solve this problem.
Theme: brooklyn.
Of course I paid for it
I've set the quality of the resized image to the maximum, but the problem has not disappeared.
You can lower quality back to 90, as it will add not needed file size only.
To solve it, please go to file fatmoon\advance\inc\class-apollo13-image-resize.php line ~28.
There we need to change order of prefered image libraries. So change from this to this After this, you can empty or delete wp-content/uploads/apollo13_images/ - it will allow images to be recreated. You use FatMoon theme ;-) Brooklyn is name of sample demo :-)
