I have a situation with the mobile nav whereby I am seeing certain active states of the menu items but not others ie. the active state seems to be white and therefore I cannot see that nav items
Two questions. How do I change this so they are uniform in colour and secondly wherein 'Customize' do I affect the states of Mobile
This is the site:
http://intertradinginternational.giveitaface.co.za
Seems like a bug in theme styles. Please remove this code from style.css line ~8033 I will fix it for next update.
It is not that. In our theme, we highlight every section that is currently visible on a screen. So as both are visible both are highlighted. If you don't like that you can try to use full height rows(option while editing rows Full height row) - it will make initially only one section highlighted.
