Starter Theme - Header Settings missing
in Starter Posts: 6
I'm trying to change the logo in the starter theme. On every help page it says "go to 'Appearance - Customize - Header Settings'" ...but 'header settings' is missing on my customize page.
What am I doing wrong?
thanks in advance
    edited July 2018 Posts: 10,970
    Very strange that you are missing these settings. Do you see other settings Panels like on the screenshot in the documentation here: https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/how-to-use-customizer/
    customizer panels
    nope. When I hit Appearance - Customize I see this (see attached image). It's not even near the screenshot in the documentation.
    345 x 351 - 14K
    I see 2 possibilities:
    1. The theme is somehow not installed fully. Try reinstalling it.
    2. Some plugin is blocking our customizer settings. Try deactivating plugins.
    Only another situation when I have seen similar issue was old WordPress version or server misconfiguration.
    Try these solutions and let me know.
    ok I will try to reinstall the theme. It's a fresh install I've used only one plug-In (coming soon). Is there a way to export my settings so I don't have to redo everything?
    You will not lose theme settings or content if you only reinstall the theme.
    However, you can export theme settings alone, but as you changed nothing in customizer, then you will not have anything to export ;-)
    https://rifetheme.com/apollo13-framework/docs/installation-updating/exporting-theme-options/
    If you have only 1 plugin, then it has to be something else.
    Could you please send me temporary access to your WordPress so I could check there what is going on? Send it here on the forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
    wonderful. thanks for your help. Just sent a private message.
    Thanks for data.
    You have an old version of the Starter theme, and what is worse you have the version that was released by mistake with a bug in Customizer. What are the chances ;-)
    Please update the theme as explained here https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-theme/manual-theme-update/
    If you want I can do it for you. I would do it already, but not sure if you made any modifications in theme files that you would like to move to the new version.
    Ah I see. Ok well if you want to update it that would be fantastic. I didn't modify anything so it's fine from my end.
    Thank you so much for your help.
    Done :-)
    In case of the logo, please remember it is defined in a few places depending on the situation https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/header/variant-light-dark-overwrites/
    In this case, you may want to look into Appearance → Customize → Header Settings → Sticky header – overwrites → Logo image & Logo image for HIGH DPI screen.
    aaah wonderful. This is the best support experience I've ever had with a wordpress theme author hands down! Thank you so much. Whenever I need a wordpress theme for anything I'll look at your product(s) first.
