Edit with WPBakery Page Builder
in Starter Posts: 5
Hi Team, after we upgrade theme to the new version, "Edit with WPBakery Page Builder" stops working , older theme we use " Visual Editor" from admin back end.
    It has to be some conflict. Try disabling all plugins except:
    1.Apollo13 Framework Extensions
    2.WPBakery Page Builder
    Then check is it working. If yes, then activate plugin one by one and check when it will stop working.
    After this please come back to me and tell the results ;-)
    Hi Team, when we tried to update WPBakery Page Builder from Wordpress Backend , it is telling us that WPBakery Page Builder can't be upgraded because license is needed. Can you check on this ? thanks.
    As the plugin is bundled with a theme it is only updated with the theme, please see https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-bundle-plugins/
