mobile menu (hamburger) Bottom right
Would there be the possibility of putting, in the mobile version, the menu on the lower right so that it is more "close" to the big toe? It is much more natural when you take the mobile that this menu is this way, and it will create more time on the page and therefore more conversion.
Could you tell me if it is possible to do it?
I attached a sample photo of another template that has it.
Thank you very much
    The idea is really cool, however, this is a place of "go to top" button, that can bring you to the header.
    Also, we have sticky hiding header option, that shows up the header with a menu as you scroll up.
    I understand the idea, however, it is in a realm of custom features. I think it could be a nice replacement for go to top button, but still, it is not an easy task to do it.
