While it has no impact on working on my pages I have noticed an "error" loading google fonts.. no clue what this is exactly.. but thought I would just ask See screenshots.
Here's another screenshot (customizer vs chrome (reality)) .. in the customizer preview the chosen font is shown but when I check outside of customizer environment (also in Elementor) it shows another font.. might be related? Thanks, Pascal
Cool! But I already have a new question Now that I selected my main fonts I wanted to use specific google fonts for "special" titles (like you did with "Herr von Muellerhof" in Chillout").. but for some reasononly certain fonts in the drop down (also in Elementor) actually display the correct font (same link to look at it, see screenshot) Thanks, Pascal
Could you share a link to this page, so I could get full link to the problematic font?
You can do it private if you need :-)
https://test.laqueria.ch is the link!
Thanks, Pascal
Thanks, Pascal
Problem is on comma at end of URL and it can be caused by lack of selected subsets.
Please select at least "latin" for font, and I will try to make theme be more "wise" when nothing is selected :-)
Thanks, selecting "latin" did the trick and also resolved the issue of not displaying the font on the backend. I used "Chillout II" as base.
Thanks, Pascal (for once not my lack of knowledge causing errors )
I will fix it for sure for next update.
Big thanks for your review Pascal(it will be online later)!
Thanks, Pascal
Are you sure it doesn't work?
