Album title image bug - Photo Proof
Hey guys,
I am facing a title image bug when I am creating a new album. The images getting squeezed in instead of just fitting in the size. I checked the settings with the previous created albums where anything seems to work, but couldn't find a difference. (compare the top two (new) and bottom two (old) albums).
But otherwise is your theme really awesome. Thanks for that!
    Hey there:-)
    Thanks for your kind opinion :-)
    Please update the theme, as there were a bug with this before version 1.11.0
  • I am not able to update the theme using the "Easy Theme and Plugin Upgrades" plugin like you recommended.
    "Installing the theme…
    Destination folder already exists. /www/htdocs/wXXXX3XX/toru-photo.de/wp-content/themes/photoproof/
    Theme installation failed."
    I have currently version 1.9.1. and I see over the Evento Market plugin that there is a version 1.11.2 is available. When I am clicking there on the install button, I am also getting the same error like above
    You probably didn't activate plugin if you have received such message. Please be sure plugin is active before updating.
    If it will still not work - delete the theme, and then update it again. You will not lose anything - don't worry:-)
  • Oh, yes, now it's working, thank you :)
