Hi guys,
I've got a strange issue with Photoproof. My front page is set up as Album in Bricks mode. I've selected 3 bricks columns - it's not scaling it correctly for my visitors, but scales correctly for me when i'm logged in. Screenshots attached. All other pages are fine. Please advice
website link:
https://egghead.photography
I see you have used some optimization plugin, and probably this plugin have disabled its functionality when you are logged in - that is why you see your page fine, and messed when logged out(when plugin kicks in).
I believe you should disable this plugin, as it removes settings for width off bricks. Not sure why it does it but is probably some glitch.
Just to clarify - this is rather issue with configuration of this plugin, then anything bad with this plugin.
