There seems to be an issue with one of my icon that rolls down when I select one of my sections. Everything seems to work as expected till I select the 'About' section. When I select that, I go to the correct area, but the icons for both the 'About' and 'Works' sections show up, hiding the text for "WORKS".
Any help would be appreciated!
site in question:
http://salemwooddesigns.com/
Till version 1.11.2 we were marking all visible on the screen sections as selected. That is why you see such behavior. However, we got many voices that told us this is not desired behavior.
So you are in luck, cause in version 2.0.0 that should be released today this is changed, and only 1 section is marked as selected :-)
So hold on few more hours ;-)
Have a great day!
