Change post title page
Hi, i must change this title "
Blog
", i set post page for first page of my site, but i want "welcome to IV3RAV" title and not "blog" title, where i change it?
    Change the title of your Blog page to what you desire :-) and you will get what you need :-)
  • Hello,
    I can not find where to change the title of the blog, can you give me a path or the name of the .php file?
    Thanks so much
  • it is possible to insert a rev. slider instead of the title?
    edited October 2018 Posts: 10,970
    GraphiksRevolution said: I can not find where to change the title of the blog, can you give me a path or the name of the .php file?
    Go to your admin area -> Pages and find your Blog page, probably named "Blog". Edit it, and change the title :-)
    GraphiksRevolution said: it is possible to insert a rev. slider instead of the title?
    It might be not easy on the classic blog page.
    However, you could instead of the classic Blog page, create new Page, and there add your revo slider and post list shortcode for example https://rifetheme.com/apollo13-framework/docs/content-management/shortcodes/post-list/
    This way you will recreate something similar to the default Blog page :-)
