i currently installed my photoproof theme and now have the problem, that the backend looks different to the frontend. I made two screenshoots for explanation.
I can see on your screenshot that you have some caching plugin(s) enabled. Please disable any caching until you are not finished with layout work.
Please also check if there are any notices displayed in the admin area.
If it still won't help, please try to disable all plugins except for Apollo13 Framework Extensions.
If you could, please also share a link to your website so I could check if CSS file that is created by Customizer is intact(now it looks like it is missing).
I will get back to you tomorrow morning(Europe) when I will be back into office:-)
You can now activate your plugins one by one, and check if new changes that you will make will work :-) This way you should find which plugin was blocking you from seeing results. I think it was some caching one ;-)
Next time please reply on the forum ;-)
I tried to check your site but it has the "coming soon" mode on, so can't check anything ;-)
i deactivated every plugin now and it seems that it work. I also deactivated the "cooming soon" mode, so you can check my side.
Thanks for your help!
Best regards
One more time - thanks for your quick help
