Album options - Custom info 1-5
Is there a way to have more custom info fields at album options? I have albums that need more than 7 or 8 custom fields.
    Currently, there is no option to increase this number, but it is a good call to add at least a "WordPress filter" that could affect this. I will look at it for next update of Apollo13 Framework Extensions plugin.
    For now, I would advise formatting your custom info as album content instead.
    In around 2 days I plan to release the update.
    You can add such code to your functions.php file(best if you would use child theme http://rifetheme.com/apollo13-framework/docs/installation-updating/installing-child-theme/ ):
    add_filter('apollo13framework_custom_fields_number', function(){
    		return 13;//change this number to any value you need
    For this to work you will need a Theme in version 2.1.0 & Apollo13 Framework Extensions plugin in version 1.5.0. Both should be released in 2 days.
