After importing the demo data for theme aurora i realized that the menu has got different (white background) which on the live demo the background covers the menu as well.
Can you please explain me what to do?
My website is :
http://kikapanayi.com/
Could you share a link to your site, so I could understand better what is the issue?
With kind regards
You can fix this by going to Appearance → Customize → Header Settings → Type, variant, background → Header color variants → Enabled.
You can read more about header color variants here https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/header/variant-light-dark-overwrites/
You must switch your slider from a "Hero Scene" to a "Standard Slider"
Best Regards
One more question as you can see on my site the slider now works, but there is an small problem and that is whe the picture is changing the is not smooth as it has to be. its just bringing the picture on. can you tell me how ca i give it a fade in visual?
Regards
Best Regards
