Getting errors on my homepage all of a sudden. The errors are below, running on PHP 7.2.
PHP Warning: implode(): Invalid arguments passed in /mydirectory/head-scripts-styles.php on line 348
PHP Warning: implode(): Invalid arguments passed in /mydirectory/head-scripts-styles.php on line 350
Have you updated the theme to version 2.1.0 and Apollo13 Framework Extensions plugin to version 1.5.1?
WIth kind regards.
I was using theme version 2.0.0 and the plugin version is 1.5.1. I just manually updated the theme to 2.1.0 and it's still giving the error.
Thank you
It seems it could be connected to fonts settings.
Try to go to customizer https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/general-settings/fonts-settings/ switch all fonts to different values, and save changes. Next get back to your old settings.
Let me know does it fix the issue.
